My De-Rustification Project
After finding out I have a leaking axle seal, I decided to do something productive so I installed the fog lights I got a few months ago. Wired them up decently. Even good grounds. I just need to get some of that nice loom stuff to cover up the wiring.
Now I need some ideas guys and gals. If anyone is still following my build thread, I would appreciate some creative ideas for how to mount a handbrake from an XJ to the Scrambler. I understand that postals have a floor mounted handbrake attached to the seat, so they must have cables that run down the middle. But my stock ones run down the driver side frame rail.
Any ideas on how to do it? Handle between the door and seat? Shorten the cable?
Why don't you do it standard CJ style like ours?
I assume you mean attached to the seat frame and running down the middle under the body? I would need to see how the cables are run and would need different cables and whatever brackets. I am open to that. I just don't know how it is done. If you are referring to something else, then please expand on that and let me know. I only know how mine is done via the foot pedal style.
This is a factory 1990 CJ-7 in Indonesia. Notice hand brake between the center console and right side driver's seat.
Sent from my SAMSUNG-SM-G850A
Yep. I was looking at that from the jeep pics thread. Too bad no pics of the underside. I will see if there are any at the PA show.
I'd be really impressed if there is. Johny lives in Indonesia and deals in a lot of Jeep parts. He may be able to get pics if not source the parts. In fact I have a shipment of stuff to send him. He also had a few items he is sending me.
Nothing magical, comes up and goes into a very similar connector that the foot one has... cable I was using was the original one, just looped and tied up out of the way...
Thanks for that great pic. So looping the cable up works, huh? That is good news.
If you think about it, the cable goes from the equalizer in the rear up to the front wheel well, through the frame, so the distance isn't that much. If you go up to about the same distance as the transmission, loop it over to the seat (would have been more distance with RHD vs. LHD) and you aren't too much different in length(again, RHD)... the only thing I see though is mounting it and having it be able to be yanked up... you really want a LHD version of the RHD one of these.
I am sure it could be made to work, but figure that they designed this for the RHD side, so working on the opposite side, in theory it would have to be backwards (facing the wrong way), or not able to be reached due to seat or console interference.
Well I have the handle from an XJ and it will receive the end of the CJ cable just fine. I just need to see where and how to mount it. I like the idea of mounting it to the seat frame somehow. I will start laying things out and playing around with it. Thanks
I'll get some under neath photos tonight for you Dain when I'm back in town
I say don't try to reinvent the wheel. Leave well enough alone. This is brought to you by someone who dropped a Chevy engine into a Jeep. LOL
Yeah, with the fiberglass tub, the seat frame would seem to be a more stable mounting point.
If the CJ cable will work and needs to be shorter you may want to try a Cj-5 or CJ-7 cable.
The 7 cable is definitely shorter, assuming the 5 woud be as well.
Good idea. I will check the lengths.
And here you go:
Seat base mounted with grommet angling forwardImageUploadedByTapatalk1468466830.011094.jpgImageUploadedByTapatalk1468466848.007412.jpg
Front cable chassis bracket on your driver's side railImageUploadedByTapatalk1468466897.676071.jpg
And where the single cable connect with the two rears at and through the exhaust support bracketImageUploadedByTapatalk1468466986.568250.jpgImageUploadedByTapatalk1468467006.252050.jpgImageUploadedByTapatalk1468467028.171525.jpg
And here you go:
Seat base mounted with grommet angling forwardView attachment 54719View attachment 54720
Front cable chassis bracket on your driver's side railView attachment 54721
And where the single cable connect with the two rears at and through the exhaust support bracketView attachment 54722View attachment 54723View attachment 54724
So awesome gazzo. Thank you very much. It looks like the cables run down the frame the same way from that bracket back. It just goes from that bracket to the center of the cab in your truck rather than going through the frame and to the outside of it and up through the left footwell like on US versions.
That helps me a lot. I appreciate it.
So I installed a new marine grade head unit in the Scrambler today so that I can have tunes again. It has bluetooth and sirius as well. Can I call it a luxury Jeep now?* I also moved the console over a bit to fit the soon to be installed handbrake between the driver seat and the console. Hopefully I will get to that this weekend as well. It is super warm so I am chilling in the AC right now.
The radio
The Mic
The antenna
Hopefully the mic works "ok". It is an open Jeep. So, probably not. It will probably be better when the hard top is on.
Hopefully I will get back out there and install the handbrake soon.
