My De-Rustification Project
Installed the XJ handbrake. I have used some screws I had laying around to secure it to the tub. But I will be going to the hardware store to get bolts and big washers to secure it permanently.
Installed the XJ handbrake. I have ised some screws I had laying around to secure it to the tub. But I will be going to the hardware store to get bolts and big washers to secure it permanently.
Looks good. How much throw do you need? It doesn't interfere when you're sitting in the Jeep with the brake on does it?
Thanks. It only needs a few clicks. No interference at all. One thing I have not tried is to flip my seat forward while the e-brake is up. While testing the spot I had the seat flipped up so the seat still flips while the handle is down.
Tonight I am going to drill a new hole in the bracket that hold the two brake cable after the equalizer bar. The angle created by the current/stock holes causes my main cable to touch the muffler. I figure if I can make the top hole directly above the lower hole, then the main cable will run closer along the frame rail. Which will help a lot. Dumb big muffler.
I went to investigate a noise/clunking sound that has been getting more frequent over the past couple of days. Found what I think is the culprit. The hub had gotten very loose. So I tightened it back up. I hope that was it.
The* I went to finish my e-brake set up. While the handbrake has been set up, the cable was still too close to the muffler and touched when tight. So I took the angle out of the equalizer by putting the holes in the bracket for the two rear cables over top of each other. Now the cable does not touch the muffler when the brake is on. It tested well. Now I need to hit the bracket with some more paint.
So today was the first time I could spent quality time with my baby. So after driving over to a damsel in distress' house to help her get her LJ Rubi Sahara started, I brought the Cj home and took the steering shaft off so I could straighten the steering wheel, then reinstall the shaft. Then I took off the leaking steering stabilizer. I will see if I want to reinstall a new one after a little driving.
Gotta take the Scrambler back to the shop that did the axle seal. Leaking again. I took the wheel off last night and there was play. I could pull the shaft out about an inch. This is really pissing me off.
My guess would be it is slightly bent... or it is very burred/rusty an it is chewing up the seals.
I honestly have no clue if it is bent. Or burred. I have not taken it apart. I have asked that when I bring it back to them, they try to figure out why. I will see if these are the reason.
I don't want to do this over and over.
If it is burred or rusty, it can be sanded/ground, right? Not sure what to do if bent.
So I went wheeling in PA last weekend. I was very happy with the way the Scrambler performed. I must have done a good job putting things back together. And the e-brake swap worked well for me. Glad I did that.
My only "carnage" was the driver side tie rod end. It is now shot. Both sides had a little bit of play, but after all of the rocks getting the better of the steering, the one end is now super bad. So I ordered new ends for both sides. I will install them when I get back from Chicago on Sunday. The drive to work yesterday was iffy at best. It had a really bad shake at 60. So I was the slow guy in the right lane everyone was mad at and had to pass.
Wow. It has been a while since I did anything to the Jeep I guess.
Well as noted above, I needed to replace the TREs. I did that at the end of August. Since then I have been dealing with a shimmy at 55-70 mph. So today I decided to do a driveway alignment. I got the measurements between the fronts and backs of the broom handles both to be 68 and 7/8s inches. Initial measurements had the front at 69 1/4 and the rear at 68 3/4. So it should be better now. I took it for a quick spin. Only got up to 57 mph but not even a start to a shake yet. So I think it definitely helped. I will know for sure when I head to work on Monday (assuming I take the Scrambler.
I also adjusted the steering wheel while I had it up. Originally it was 90* off to the left. Then I adjusted it and it was maybe 10* to the right. So now, of course I over compensated, and it is slightly to the left again. But a lot better. Being AR is a curse.
I'm no alignment expert... in fact I don't know anything other than what I read on the internet, so take my thoughts with a grain of salt. ;)
My thinking is, in a perfect world, zero toe would be the way to go. However, every link in the steering system has a little bit of play: wheel bearings, ball joints, tie-rod ends, sidewall flex, etc.
As we drive forward, the wheels naturally want to splay outward (as evidenced by every photo of a broken tie-rod I've ever seen). There's just not enough caster to keep them trailing straight.
So, if you adjust at rest with the correct (slight) toe-in, then when the wheels splay outward enough to take up the slack in the system, they will end up running straight when you're driving down the road.
Again, I might be talking out of my a**... maybe someone more educated will chime in...!
Makes sense (both responses). So maybe I will dial it in a little more. I will see how this goes first. Had to get rid of the vibration. It was shaking me to death and making the top squeak against the tub. So annoying.
Oh on a more funny note, I have started carpooling with someone. After two weeks of 1.5 to 2 hour rides each way every other day, he stopped carpooling with me. I noticed that he held the grab bar like it was a matter of life and death. I even put the doors on for him. I guess he doesn't like the Scrambler.
And Thursday evening a coworker who lives nearby asked for a ride home. The next morning she told me that she is never going to ask for a ride home again.
And really, ai drive like a grandma compared to others on the road around here. She did not feel safe in the Scrambler. Oh well.
