My De-Rustification Project
Your first paragraph is why our moderators need to try a last ditch effort to make other arrangements to keep the photos. Forget the ease of access. It's the PHOTOs.[emoji22]
I remember that blizzard... you are getting a decent shot tomorrow i hear somewhere down there. We are just barely avoiding it up here [emoji1303]
Should be a little south of me. But I will be driving to SC and back on Sunday, so that won't be fun.
Been a while since I did anytting. I guess that is good. Today I installed a new diff cover for my front. I went from this..,,
To this ....
Getting ready to hit the rocks a few times this spring/summer.
Bumpers were getting a little rusty in spots. So I broke out the grinder then repainted with the same stuff I put on the frame. It ain't pretty, but it is easy to touch up after hitting the rocks.
Othing exciting. But I droped the Scrambler off at a welder friend who is going to reinstall my sliders to this new frame. And he is going to tie the roll bar into the frame as well. I have been wanting to do this for 11 months. Since I put it on the new frame. Ugh. Glad I am finally doing it. Just wish I knew how to weld. And had a welder. And could do it as well as he can. I will take pics when I get it back.
I have a mig welder and a plasma torch and know how to use them but my neighbor is so much better at it than I am that I get him to do all my welding. Keep doing it the way you are doing it now.
I did mine in Hammered Rustoleum and it was a great call for that very reason. I tend to do a quick "refresh" about once a year simply by taping off my stickers and holding a piece of cardboard behind them to shield stuff while I happily spraybomb away the wear :smokin:
Working off the same theory whit the build I am working on right now. Currently used Rustoleums new equipment paint and while it is very hard it seems color is off. However being able to give heavy wear spots a quick touch up every so often is definitely a benefit.
I think we are using the same paint. I like it.
So a local guy/fabricator (Steve at Xtreme) is redoing my sliders and finally getting them installed on this frame along with tying the rollbar to the frame. He sent me this pic today. Should have final install and paint tomorrow.
Steve's a good guy. Even has a Scrambler hidden away.
Yes he is. And maybe I can sneak a peak at it when I pick mine up. I did not have time last weekend when I dropped it off. He was telling me his plans for it. I hope he actually gets to work on it some day. He seems so busy with other rigs and other jobs.
So picked up the Scrambler yesterday. The steps/sliders look great. And the rear rollbar feet are tied into the body mount. Apparently my exhaust bracket was broken so that got welded up as well since Steve was there.
I also added some sticker hp
Then I swung by Jim's to get a chrome wheel to use as my spare.
I plan on getting new tires this week. I am gonna order 33x10.5. I should have the space for them. I am thinking about a 4" lift soon, but taxes were done this weekend and I owe too much to think about the lift right now. Grrr
Oh and the support on the front for the sliders is set up for when I decide to install a front cage. The bar can come straight down the front and will be able to use that support as a tie in spot.
Got some new tires. Went with 33x10.5 BFG TA KO2s
Don't fill the wells up as much as I was afraid they would. Noticed my speedo was off again. But not much. Showed 23 when going 25. Looking forward to see the difference at speed.
New pic with the top off. Just because.
Oh and I have had a bad shake in the front end that got worse with the new tires. Jim and I both thought it would be a bearing. Inwas able to swap the driver side and got rid of the play that was there. But could not do the passenger side as the upper caliper allen head bolt was stripped. Grrrr. Took it for a test drive and it is about 98* better. So I am happy. But still need to seap the passenger side as it has some play in it.
Your speedo is not off that bad. I don't even have tires that big and are off around that much
It was off by about 10mph until I switched gears to the 3.31. Then it was right on the dot running 31s. Now with the 33s I am showing 23 when doing 25 and showing 50 when doin 54 per my gps. So not bad at all.
And today I was able to do the pass side front wheel bearing without taking the brake caliper or rotor off. Obviously could not swap the race on this side, but I called it good enough for today. And the play in that wheel is gone now too. And my drive tonight was smooth. So I am happy again. We will see what itnis like hitting the highway tomorrow.
I also added a metal cable to act as a tether for my gas cap. Maybe I won't lose another one now. I may redo it. I am not super happy with it, but we will see how long it lasts.
And today I was able to do the pass side front wheel bearing without taking the brake caliper or rotor off. Obviously could not swap the race on this side, but I called it good enough for today....
So, just the outer bearing...? How did the old one look? :shrug:
Honestly, they both looked fine when I took them out. The nuts holding them in were pretty darn loose when I took them apart, so it may have just needed tightening. But since I had the new bearings, I swapped them anyway. I tossed them in my collection of trail spare parts.
