Power Steering fluid Leak
Hello, Im back:
For what it's worth, I ordered a new/re-built H1 1996 steering box from CARiD. I ordered it about seven day ago and got it yesterday and it turned out to be cheaper I was happy with the service. There follow up was good, the folks on the phone were great and the delivered when they said they would. I guess you can't ask for better than that..
So I installed the box onto the Jeep today & before I went any further I figured I would just check the power steering lines and hook them up to the box.
Well - One line does not fit, the end is to long. What do you fellas do in this situation, is there an adaptor that I need?
Regards.
For those of you that have upgraded to the 1996 H1 steering box, did you have to change out the power steering lines?
The male connector that is to big is on the end of the high pressure line that is screwed to the back of the steering reservoir.
If I purchase a new high pressure line would anyone know if the male fitting at the reservoir end is the same size as the original
or do I have to get this line custom made?
Thanks
I used one for a 2002 H1. Not sure if is the same for 96 but I'm guessing probably so. Should not need to do anything different with the OEM lines. Assuming they are for an 80 or newer, they should mount right up to the gearbox. Looking at your photo, I'm wondering if there may be an adapter installed in that port? Both ports should look about the same inside. I've seen people use adapter fittings to make a newer box fit an older hose. Maybe it got left in there when it was rebuilt/resold?
Or maybe it's just the wrong box?
NO - don't tell me its the wrong box... :eek:
The other original line that has the magnetic filter on it fits - it's just the male connector on the pressure line is to long.
The original lines are on an 82 model.
Mine have all been direct bolt in swaps using the original CJ o-ring style power steering lines. No adapters or custom lines needed. I'm not sure I'm following you on your two posts about which line is to big? Is it the line that threads into the back of the power steering pump reservoir or the larger line on the steering box itself? Does the return line thread into the steering box okay?
Sent via smoke signal
Hi:
The male connector on the high pressure power steering fluid line - the one that is screwed to the bottom of the power steering fluid reservoir (I only assume it is high pressure, since the ends have metal attached to them) it is to long to go in the port on the steering box.
When I look into the port on the box there is that gold ring and the end if the metal on the line hits that first so I cannot get to turn any thread..
Does the return line port have the same gold ring as the pressure side port? Does the return line thread into the box okay?
I just looked at my factory box and lines. The fittings connect directly to the box.
I think what Spieg is saying is the part with the gold piece in the pic looks like an adapter, it should be removed and your line would go in its place.
It's hard to tell from the pic angle, but it does look like that is a fitting threaded into the box.
Have you tried removing that and comparing the ends of it and your line fitting?
The return line does not have the gold ring. The return line fits the port just fine.photo.JPG
I'm not positive but the brass bushing inside the port looks like something used to convert to the older style flared fittings. I would see if that gold ring can come out.
It almost looks like both the ports on the steering box have some sort of fitting installed. I don't remember there being any hex head shaped pieces installed in the ports on my H1 boxes. Will check when I get home.
Thank you very much. I did try to see if the brass ring came out. I will admit I only tried slightly - did not want to do any damage, but i will have another go today.
If the fitting, (the ring is in), is threaded into the steering box.
You can unthread the fitting from the box and push/punch/press the fitting out from the inside.
So I just went out to the Jeep and put the return line in the port - its screws in but does not sit flush it only screws 1/2 way in.
That fitting in the box appears to be an adapter for the o-ring type fitting on your existing line.
The o-ring should compress against the shoulder inside the fitting creating the seal. As long as the fitting tightened down and compressed the seal in the fitting it should be good.
Not sure if you went with a new o-ring, that would be my only concern.
Ive always just pulled the plastic covers and mounted my lines to the gearbox housing.
Spieg, that is also what I stated here:
Maybe he is seeing something we don't?
I haven't done the upgrade yet, so I don't have first hand knowledge like you do.
Wayne?
I would like nothing more that to buy you chaps an ice cold beverage right now, your brilliant.
So both adaptors do come of the box, and both ends of both fluid lines fit both ports.
They are to long though, they do tighten down all the way and I cannot remember if they were flush on the old steering box?Should this be an issue if the do not tighten down all the way??
FLCJ8 - You mentioned the O-rings. Are you talking about the O-ring at the very end of the fluid line? If so I have not replaced them, If you think I should then I will.
If you are not going to replace both lines then I would at the very least recommend replacing both o-rings at the end of the lines.
Thought those adapters looked out of place on the box!
Threads showing on the nuts at the end of the lines is perfectly fine. The o-ring is sealing it at the bottom. Looks the same as mine.
