Yavapi county (its home) is smog exempt.
That's great you don't have to deal with it.
I just assumed all CA had emission testing.
I'm trying to see what my options are for a possible move to NV. They have testing in only two counties, trying to avoid them if possible.
Yavapi county is in AZ, That is where Prescott is. There are several other counties in AZ that are exempt zones, that you might try. Not sure about NV. Bought it as a family vehicle and it will stay on a ranch in AZ.
Photo of the 401 Engine stamp is attached I hope (Arrrrrrrrr)
You wont like that 401...I hate mine!
But seriously, if you get into it for anything, there are a few tricks that you should know, don't hesitate to ask.
However, there are a few things inside AMC V8's that require a little extra attention if doing any engine work that your average engine builder may not be aware of...primarily in the oiling system (cam, timing chain gear, fuel pump eccentric and distributor drive gear area, etc.) I have built several and can pass on a few tips and links if ever needed.
