Upgrading Brake Booster
DirtyB
Crazy Cajun
Port Allen
LA
I have a brake booster on my 8 now, but something is wrong with the proportioning valve and/or the diaphragm. Despite bleeding the brakes and having 2 additional mechanics look at it, I can't figure it out, and I'm officially giving up. The brakes work, but there's very little resistance on the pedal. I'm not sure where this brake booster and master cylinder came from, but it's not original. I want it out.
I want to buy this...
https://www.ebay.com/itm/1974-86-Je...ash=item4af42e0507:g:6C0AAOSwfcVUIWiJ&vxp=mtr
I'm a little worried as I don't know the quality of parts. I'm really looking for an easy solution, so I'm trying not to piece together a system. i also don't want to spend extra $$ (but I will spend the necessary $$ to get my brakes working correctly!!)
Has anyone worked with GPS Automotive? just the fact that they have a tech support line is encouraging to me. This should be a bolt up solution (except for the brake line work).
I'd rather not buy a YJ set up - used stuff. Too many details that might go wrong.
I'm running 32" tires and a fuel injection 4.2, so I don't need anything special.
Looks complete. We just used a Right Stuff kit from Summit for our Impala. Went on really easily. Similar kit. Same parts. We had similar symptoms. It was the master cylinder, but I wanted to replace it all anyway.
Probably already tried it, but did you adjust the length of the shaft between the booster and pedal? Lengthening that was the trick that finally got me a firm pedal after swapping on the Vanco booster.
yeah. I've messed with every adjustment possible. It's also a single diaphragm, so maybe I'll like this dual diaphragm better. I can lock it up on a gravel road but not on dry pavement. It also "wiggles" just a little when I apply the brakes which makes me wonder if the proportioning valve and/or metering valves are really correct. Who knows what the PO installed? I've spent the last 12 years correcting his goof ups. This will be just one more thing.
I just installed a conversion kit from summit for manual to power brakes on a friends scrambler. It included all the brackets, booster and master. Has very good stopping power, much better than my stock 81 power brakes. Only complaint is that the master is difficult to open and close.
I bought a ebay mc/booster combo. Pedal would have half the travel then was rock hard. Never could get it to feel right. Got this setup https://www.summitracing.com/parts/tff-2124nb. One of the other forum members (can't remember his name) installed it and liked it. Quick install and pedal has a good feel. Haven't driven the cj8 (not completed yet) but brakes have a good feel like a properly working brake setup.
I installed the Tuff Stuff Kit. Worked great, very pleased.
I bought a dual diaphragm kit from Morris and it likes to slowly lock up the rear brakes and make them drag until I pull off the vacuum line to reset it. I have adjusted the rod inside the booster according to the directions and it continues to slowly push on the brakes for me under vacuum. It looks like the same setup on the ebay link.
Might have an air bubble in the master cylinder.
Something I learned about recently where the master cylinder needs to be bleed separately from and before the rest of the system when it has been dry.
I have a leaking MC so going to have the booster replaced while I am at it. The Tuff Stuff looks nice- and it's made in the USA. Randyzzz- Is it a direct fit/ plug and play? When you say "kit" did it come with something other than just the MC and booster?
Not direct- I had to do some modifications to the pushrod, but I'm not sure if that's because I changed pedals earlier or what. I think I had to shorten the pushrod and use the old clevis.
