- Rochester
- Mi
I'm considering going down the rabbit hole of swapping a 360 in to my 8 from a wagoneer. I have a line on a good engine from a friend that was going to put it in his 7 but decided to keep his 304. As I get into this I need to know what to plan for. I have a guy lined up that will rebuild the engine and he is asking me as we are getting into this what is the best cam and value set up to run for that engine. The scrambler is going to be 90% on road 10% off road and turning 33s. So I am looking for some input there on what you guys are running.
Looking into other details with the swap:
Fuel line 3/8" correct?
Motor mounts, M.O.R.E.
Advance adapters or novac to mount up the T5 and Dana 300
Radiator? Will the existing radiator work or is there a different radiator that I need to go with
What is the engine paint color code for the blue.
Exhaust, I plan on keeping the existing exhaust manifold. Dual exhausts seem to be the right direction beyond that. Is there a manufacture that you would recommend.
What other large items am I missing?
Thanks for all the help.
