- Minneapolis
- MN
Shhh... the Jeep gods will hear you. It's not allowed to have everything working properly.
Nicely done!
Nicely done!
That's the most accurate statement EVER!!!Shhh... the Jeep gods will hear you. It's not allowed to have everything working properly.
Nicely done!
Wondering what the hatchet is for, splitting hairs or keeping people away with aggravating questions ?
The passenger side axle shaft ujoint took 4 hours to change. I broke a vice before resorting to a press. Was ultimately successful, just wasn’t as fun of a project as I hoped it would be.
I am now wondering if I should keep and twin stick the Dana 300 already in it or use the NP241C with SYE installed that is sitting in my garage.
The twin stick might be nice to take the front out of 4wd when in low range to make turns.
NP241 shifts the front output shaft outward to make more room for drive shaft clearance.What would be the benefit of the 241C over the D300?
If you decide not to use the Np241c with SYE let me know I know someone looking.NP241C with SYE installed that is sitting in my garage.
Not sure if you already know this, nor am I 100% sure this will work in your case.The float filled with fuel and stopped floating.
I saved this from years ago.
https://www.cjponyparts.com/fuel-tank-sending-unit-float-1964-1968/p/FSUF/
