2WD 4BT Cummins/ Allison auto ‘82 CJ-8
cblfhs
Quadriplegic Cj8 <3er
Highland Park
IL
82 CJ-8 (2wd 4bt/Allison auto swap) Frame-Off Rebuild
Year: 82
Model: Standard
Final tire size: 31”?
Build details:
I bought this project off of WebsterCJ8 on the forum.
I broke my neck a couple years ago and I have found a friend to build me a 2WD jeep at a price I can sort of afford ha ha Ha ha ha Just Empty Every Pocket = jeep
this might be one of the first disability equipped Scrambler‘s. I am a wheelchair user now so this will have hand controls for gas and brake with the left-hand, a tri-peg on the steering wheel for the right hand, and a crane in the bed to hoist my wheelchair.
I also bought a Four cylinder Cummins frame cut from this dude Chad McKimmey on eBay. Computer controlled engine and five speed Allison automatic transmission from the radiator to the back of the driveshaft...
My friend in Minnesota who I am paying to assemble the jeep has just pretty much finished holding everything together in terms of initial assembly with the stock drivetrain, this might be sort of a lazy build thread because I do speech to text and I am getting pictures from my friend who is building the jeep for me but anyways here it goes ....
More ext pics
This looks like a very unique build, and I love it!
I also love that you have a vision of what you want to end up with, and you're sticking to it!
It looks like your Scrambler came with the rear hoop of a Rock-Hard cage installed... did you get the rest of the cage with it? If so, it will provide plenty of hand-holds, to make it easier getting in and out.
I put a Rock-Hard cage in mine, and removed the stock roll bar completely. I like this setup, because now I have 3-point seat belts (which I didn't have before), and I have much better access to the bed. I mention this, because it looks like the stock roll bar might interfere with your chair lift.
I look forward to following this build! :cheers:
You make a lot of fantastic points! I love the look of the factory roll cage and I may be sending my friend and builder, Alex a spare wheelchair so he can see how the chairlift will work in conjunction with the Roll Bar.
Thanks!
My friend in Minnesota has had a crazy winter! Will give you guys updates ASAP
Probably the last time this stock motor will run inside of this frame, I’m looking to get $500 or best offer for the stock engine transmission and transfer case
Located in Mankato Minnesota, possible delivery to Chicago area but you might have to throw in some diesel money or something for my friend Alex
