- Ashburn
- VA
So as the title says, I found a deal online for a dana 300 that someone had swapped in the 4 to 1 gears kit and a twin stick set up. I bougt it for less than the parts and this was never installed after the conversion.
It has an adapter/clocking ring for a NV3550. According to the advance adapters catalog, it has the same bolt pattern as the dana 300 only rotated.
So that makes me think I can just bolt it up as is (maybe change the rotation of the ring). Otherwise I would need to take off the ring, and the longer inout shaft and use the inout shaft from the dana 300 I currently have on the Scrambler.
Am I right in my thinking? Anyone done this or know about the NV3550? I have a T-176 that I am planning on mating this t-case to.
