8.8 ford matched with?
I found a junkyard 40 minutes from me with (2) 1977 Ford F-150 fronts...$300 each (whole axle). These should be high pinion w/ 5 on 5.5 already. Seems like a good deal.... I'll drag the trailer down there one of these Saturdays.... Hopefully warn prem lockouts... Should be the "big" u-joints...
KK
https://www.therangerstation.com/tech_library/Dana44.shtml
That sounds good. I think I am going with a chassis cab 14 bolt and either a dodge or chevy 60.
KK
That's a great axle . . . for a YJ. Fords are driver's-side drop front differentials; if you want to keep your Dana 300, you need a passenger-side drop.
I've been searching for a D44 front, passenger drop. Dodge and selected chevy is where to look. I've not found any around Houton. All seem to be around Dallas.
Chevy CUCV military trucks have the best ones, but are $$$.
Both dodge and chevy are spring over axles, so you can run more compliant no lift springs.
Jeep full size trucks all run spring under.
Dodge have some that are CAD, and some are conventional. CAD can have the split axle replaced with a solid axle, but will still have the funky chunk on the tube.
Careful with chevy of the 80's they could have a corporate or dana. Both were used interchangeably on the production line. Both are good axles. But the corporate is a GM axle, dana is a mfg neutral axle.
Wow...not sure how I studied that page as long as I did and missed that. I guess sometimes you look at a page too long and ignore the important details.... I'd really like to be high pinion.... I guess custom is the only way I'll get that....
