A couple basic troubleshooting tips:
- The 12 volts in the vehicle needs a complete path from the battery and back to the battery.
What this means is you are testing for a 12 volt positive output (such as the blue lead) then use the battery negative post for your negative return. If you are testing for a ground signal (such as the neutral safety switch lead to the solenoid) use the positive battery post for your 12 volt positive source. Of course this is based on a good battery, which we have already confirmed.
- If using a multi-meter use the DC voltage setting that is just above your expected voltage.
In your case I would set the voltmeter for DC voltage just above the expected voltage and confirm that it is functioning properly by testing at both battery posts. This will confirm the leads are connected properly and also give you a reference point of the readings you are looking for.
Connect the negative (black) lead to the battery's negative post and the positive lead to the blue lead that was disconnected from the solenoid. As stated above... the ignition key needs to be turned and held to "START".
You should get a reading similar to your previous reference reading if the switch/wiring is good.
If you don't further testing will need to be done at the fuse block/ignition wiring.
Either way, I would suggest testing the neutral safety switch function.
Connect the meter's positive lead to the battery positive post, then connect the negative lead to the switch return wire that attaches to the solenoid.
You should get the reference voltage reading when the transmission is in PARK or NEUTRAL, and 0 volts in any other gear position.
If you don't get these results you can jumper the NSS post on the solenoid to the battery negative to simulate a good switch function.
Make sure the transmission is in PARK or NEUTRAL when doing any cranking tests with this bypass installed.
Time for dinner...
try these steps and report back
