Speedhut Speedometer GPS sensor mounting location
RMNP CJ-8
Well-known member
Estes Park
CO
For those who are using Speedhut gauges, where are you mounting the GPS sensor?
I would like to find a place where it will work but not be visible or look out of place.
Anyone have luck with a mounting location?
Thanks
I put mine on left side wall by where my left foot rests when driving but the thing quit working after only 1 week
Mine is on the top of my driver's side rear wheel well mounted speaker box. It's out of the way, tucked under my roll bar mounted hi-lift.
Thanks
I have READ of it being mounted in the fresh air intake below the cowl grille.
Sounds like a good location from the visual aspect, never heard definitively how well it works there.
Probably worth tie wrapping it there temporarily for a trial run. :shrug:
I was thinking of making a small tab using the loop holes above the rear view mirror. But I like the idea of the fresh air intake too. If that would work it would be the easiest.
Thanks, I was considering placing it on the top rear of my storage box in the bed.
I also read someone mention the fresh air intake. I was hoping someone had tried placing it there and had duck in that location.
I have put several in the fresh air intake and had good luck with that location. If you are only using the GPS for MPH I have noticed on occasion it may take a mile down the road to get signal from the satellites before your speedo starts working. Especially when you pull the jeep out of a garage.
Thanks
I'll have to give it a try there first.
I have mine inside the fresh air duct and have one of the Rugged Ridge diverter covers on top of the factory cover and it works like a charm. Takes HEAVY trees or a tunnel to kill the signal. It's VERY weird the first time you're at speed and notice the needle drop to 0 :rotfl:
Inside a metal tub or fiberglass? I would think a metal tub would destroy the GPS signal strength.
