- Bedford
- NH
Are you wanting to run the older style heater? Seems like alotta work if your cowl is good as is for the later more common box? Hmm?![]()
Doesn't the bump up one shed water a little better in theory? I agree the flush mount looks much better, but it seems it would be more prone to take in water running across the hood and cowl. However, I say all of this yet TJ's had it stamped flush into the cowl.....but also had water pooling issues. Maybe consider wire mesh beneath the grate to help prevent the drain lines from clogging with organics....?
Just thinking out loud... Anxious to see the solution as you always do stellar work.
How's the trailer pulling after its summer re-fit? All looks good!
Looks like you are building a beautiful shop there!![]()
