The "1" on a scale of being a mechanic is a little concerning, and I'm not poking fun. Stabbing a new distributor is very simple...in premise...but even people like me, a self-acclaimed 8-out-of-10 on the mechanic scale, occasionally stab it 180 degrees out or mismatch plug wires and have to deal with the diagnosis of no start or violent backfires until eventually uncovering my oops.
If your rig is still running fine, I'd stick with a simple tune up of plugs, wires, and coil. The HEI (high energy ignition) coil-on-cap upgrade is usually for simplicity because it has the mutli-spark module in the cap instead of built into the dreaded "ignition module" that leaks potting sap on the fenderwell eventually. There is also the option of the "nutter bypass" which retains a lot of the main components but cleans things up a little bit.
As for the $100 scamazon HEI dizzy....I'd steer clear if it's your daily or frequent driver. I've run the cheap HEI dizzys on dedicated off road rigs, and the fit and finish isn't great. I had one in a 351M powered '78 Bronco, and the clearance on the base was so loose that the distributor would literally dance around as the engine ran which eventually started to wear funny on the cam gear. Buy nice or buy twice, as some would say...
