Mystery device on my '81 Scrambler 258 6-cylinder
DRdalequail
San Angelo
TX
What is the function of this module? It's about the size of a pack of cigarettes and is located on passenger side inside fender, just across from the alternator. I unplugged it, started engine, and didn't seem to affect idle performance.
Did your Jeep have air conditioning?
Some "pre '83" models had the "Sol-Vac" on the carburetor, this module controlled the "Sol-Vac".
Basically, what you took a picture of is a computer that controlled a thing on the carburetor which would slightly idle up the engine, for different reasons.
I have found these on some pre '83 Jeeps with OEM or dealer add on AC, and pre 83 CA emissions models.
Not much information out there about them. If it works, and you have AC and a carburetor, it is nice to have. When the AC clutch engages, it will bog down the motor some at idle. This box will make the Sol Vac extend and slightly up the idle to compensate.
Thanks spankrjs! No AC on my jeep.
No problem. I have seen them on pre '83 Jeeps with no AC, and that did not have CA emissions. Kind of hit or miss. The Factory Service Manual I have does not mention this device at all.
If you can find/read the part number off of it a Google Search will turn up some information, not much.
I have seen these things primarily on 1981and 1982 models, before Jeep installed the full blown computer behind the dashboard computer controlled carburetor.
