Somewhat productive day. I attached the head pipe so that I could install the O2 sensor. That is when I noticed that it routes the exhaust to the passenger side. I am not sure that I want it that way, but this will at least have the O2 sensor working.
Then I installed the Tom Woods drive shafts. Damn is it difficult to tighten the little drive shaft u-bolt style retainers. If anyone has helpful hints for that, let me know.
Then I started it up (still jumping the ASD circuit) and let it idle for a long time to get it up to temp and check for leaks. Yay. No leaks. So I moved on to running the lights harness and installing the lights. Some turned on. Yay. So that is better than last time. That is obviously grounds, so I will deal with that.
Anyway, here are some pics. I will focus on the ASD and install the winch and front bumper next.
Progress. At least it is looking like a Jeep again. And can move around if I need/want.
And I am curious as to the possible problems of running without the ASD relay.
