Your thread got me going on mine today. Pics tomorrow if all goes well.Is everyone using drive by cable throttle bodies?
I was starting to wonder the same thing.Is everyone using drive by cable throttle bodies?
Drive by cable is more popular I think. It requires less parts and less custom stuff, and people feel it responds “quicker”. However response lag can be fixed through tuning, and drive-by-wire makes adding cruise control a simple wire connection or a couple switches at most.I was starting to wonder the same thing.
I would kill to have cruise on my Postal. I fully support the idea of adding it if at all possible. You are, after all, adding an engine that will allow you to cruise highway speeds all day long easilyI ma doing drive by wire just so I can run a switch panel to operate cruise control. I may never need it but I like running cruise on the highway so why not have it.
I took a pedal from a Silverado. Cut the arm into 3 pieces and flipped the center so it angles the opposite way of stock. Had to play with the angles a lot. The top bolt hole will go in an existing threaded firewall hole with a tapered spacer. The bottom I trimmed and bent to match the firewall contour and it will have 2 more bolts.
View attachment 92113 View attachment 92114
Just a warning- I don’t know if welding on the pedal with the sensor attached could cause problems. The sensor comes off with torx security screws. If you do remove the sensor first, make sure the potentiometer inside the housing doesn’t move while it’s off.
Also- don’t forget to leave room for carpet below the pedal. If you’re installing carpet, that is.
@revho, get in here...What controls are you guys using for cruise control? Steering column stalk? Buttons/switches?
when it hits 1000% throttle.
