MomoJeep
- Seattle
- WA
Am I missing anything?
Using this gear ratio calculator: https://www.novak-adapt.com/knowledge/transmissions/manual/t4-t5
Stock setup: 28.5" tires / T5 with .86 5th gear / 3.31 axles
65mph in 5th gear = 2181 rpm
Current setup: 32.5" tires / AX15 with .79 5th gear / (4.10 axles)
65mph in 5th gear = 2176 rpm
Please check my assumptions:
(1) Stock CJ-8 tires were 28.5" Dia?
(2) By picking 4.10 axles, the engine rpms stay essentially the same even though tire size & 5th gear have changed. But is there any reason the rpms should be different? The Jeep is heavier now.
(3) When I'm cruising down the freeway, 5th gear will be used the most?
Regarding #3, I currently cruise in 4th because I've got 3.31 axles. If I change the calculations for 4th gear, both transmissions are the same (1:1). Now the axle ratio that makes the rpms equivalent from stock to modified is 3.73. In 4th the rpms @ 65mph would be 2755, probably too high.
Question: do people with 5speeds cruise in 5th primarily?
