High Steer Arm Recommendation
sphoss
New member
austin
TX
I have disassembled my 74 Wagoneer axle and decided to add a high steer arm on the passenger side for the tie rod. Planning to keep the drag link on the wagoneer knuckles. I was looking at a couple of options from:
WFO:
PartsMike:
Couple of questions:
- With my Spring under axle RE 4.5" lift, do I need to go with the 10 degree offset
- Is there any issues with going with a taller arm in case I decide to go spring over axle in the future.
- What arms are you using?
Thanks, in advance.
WFO:
PartsMike:
Thanks, in advance.
I did crossover on Copper. RE 4.5Extreme. I used a flat arm and had minor issues with the drag link rubbing the frame on full compression. But it handled great!
I did the Parts Mike arm. Also, RE 4.5, spring under Waggy axle.
I have 4" BDS springs with that steering arm from Parts Mike.
The only issue I see with a taller steering arm would be the drag link going downhill towards the pitman arm. My springs have likely settled a bit since new but the knuckle is slightly higher than my pitman. That said, it drives steers and handles better now than it ever has.
I used Parts Mike double arms (tie rod behind the axle) on my CJ-7 with Scout 44s. I tore them in half twice at the middle hole and a friend of mine with the same arms tore his once. Normally PM is quality stuff - so, I was surprised. We both replaced the PM arms with another brand (I can't think of it at the moment).
I don't see the double arms for sale any more on his site - so, perhaps it was just an issue with those arms?
Just installed Sky’s Offroad arms. The axle has Reid knuckles, four hole, but they have three hole arms available too. I like the fact that they are tall arms, 7/8” taller, but they use short studs for strength. The holes are recessed. Went together great. Currently running a crossover but I did pick up the driver side arm for future full high steer. Goes down the road at 75 with one finger and no steering stabilizer. Running SOA with 1 1/2“ lift leaf springs from RE. Changed the pitman arm to a longer, stronger WFO flat blank drilled for one ton tie rod.
Have you guys had any issues with the tires scrubbing while making sharp turns? I trying to understand if what level of steering geometry needs to be accounted for in setting up the drag link locations relative to the spindle pivot points. Typically cars are designed to have Ackermann Steering geometry to keep the tire turning on the same radius center.
Wagoneer Wheelbase: 110
Scrambler Wheelbase: 103.5 + 1" for YJ springs
CJ7 Wheelbase: 93.5
The interesting part of this if Jeep used standard CJ axles on Scramblers, then the Ackermann geometry is wrong to start with. Maybe I am overthinking the engineering on this too much ;)
Yes. Pretty noticeable and only when turning to driver. I’d like to mesure the angle of the tires soon just to see how far off the are. It isn’t really a bother unless turning in slick conditions. Then the front end pushes, reducing the turning radius. I have no idea if this can be improved either. I’ve heard wheel backspacing plays a role. the front is 65” wms with -12mm wheel backspacing.
