laffman
- Imlay City
- MI
I'm hoping one of you out there with factory rocker trim can help me out. I'm looking for pictures of the trim ends mounted on the Jeep. I was a able to find a set of rocker trim on Ebay. Overall, they're in good shape. They just need a little hammering, grinding, sanding and paint to look good again. When I test fit them. they seem too long. The back end overlaps the stamped raised lip around the wheel opening, preventing the trim from sitting flat on the body. I have a WO replacement tub, so I'm guessing the wheel opening is slightly out of position. Wouldn't surprise me with everything else we had to fix with that tub. Here is a picture of mine mounted at the rear wheel opening, so you can see what I'm talking about. It's as far forward as possible, with the front edge correctly positioned with the front fender. Might have to grind it to fit flush over the lip.
