Pictures of mounted factory rocker trim
laffman
Imlay City
I'm hoping one of you out there with factory rocker trim can help me out. I'm looking for pictures of the trim ends mounted on the Jeep. I was a able to find a set of rocker trim on Ebay. Overall, they're in good shape. They just need a little hammering, grinding, sanding and paint to look good again. When I test fit them. they seem too long. The back end overlaps the stamped raised lip around the wheel opening, preventing the trim from sitting flat on the body. I have a WO replacement tub, so I'm guessing the wheel opening is slightly out of position. Wouldn't surprise me with everything else we had to fix with that tub. Here is a picture of mine mounted at the rear wheel opening, so you can see what I'm talking about. It's as far forward as possible, with the front edge correctly positioned with the front fender. Might have to grind it to fit flush over the lip.
I'll grab a picture of mine later this morning. Also on a W-O tub.
Here is front and rear photo. To my knowledge these came factory installed and never removed
  • Like
Reactions: SKT
Thanks @rubclt. That's what I thought it would look like. Guess I'm going to grind mine to fit right. If mine weren't already slightly damaged, I'd have a hard time do it to such a rare trim piece.
@laffman check your height... the rocker is lower than tub by 3/8”. The front appear to have a ridge that aligns to bottom 3/8” up from bottom on aluminum rocker.
Height doesn't seem adjustable. It's set by the holes in the tub and the bolts riding in the trim slot. I have the bottom lip of the trim up against the bottom of the tub. Even though I had to drill the mounting holes in the tub, my original tub already had the holes. When I test fit the trim to my original tub, it mounted the same way, trim lip against bottom of tub. And it lined up with the weathered line left by the original trim.
Thanks for the tip. I did go double check.
