AMC 20 Rebuild
Ronnander
New member
Savannah
Ga
I'm currently replacing the ring and pinion in my 81 CJ8. The original pinion bearing was shimmed behind the inner bearing cone. I understand some were shimmed this way and some were shimmed behind the pinion bearing. The installation kit came with shims for the pinion bearing but not for the inner cone. I don't think it will matter which way it is shimmed but it came originally with a 100,000th shim behind the inner bearing cone. I would put the old shim back but it was cracked when I removed it. The problem is I can't find the shims for the bearing cone. I can find plenty for the inner bearing. Does it matter which waay I shim the pinion?
How are you measuring for the shims required? Unless you're lucky the replacement ring and pinion will need different shims.
As i recall you have to temporary install the pinion and take some precise measurements to the axle centerline to figure out the shims required.
I rebuilt mine recently after doing the front. Shims to the bearing carrier were between bearing and housing. So destroying new bearings to allow pulling on and off for shim resetting were not necessary. It is the same for the pinion bearing at the base. That shim for pinion depth goes between bearing and housing. The final pinion bearing, I used a new one hollowed out to allow ease of removal and did away with the crush sleeve in favor of shims for setting preload. AMC used a machined shim...so what ever was calculated at assembly, a shim was machined to those specs. Your kit should have the shims for the above mentioned set up minus an extra bearing.
Google "AMC Model 20 rebuild and setup". It is on the jeep forum. Excellent write up...
I bought an extra set of bearings and had them honed at a machine shop so they slide on and off. My differential came with the shims between the bearing race and the housing. My kit came with the shims that go between the pinion and the bearing but not the bearing race and the housing. These are a little larger than the carrier shims. I'm trying to find a part number for this shim.
Ratech manufacturing will have the shims to fit between bearing and housing. Looking at my write up on my 20 rebuild, I realized that I didn't mention here that the pinion inner bearing outside race will need to be ground down to allow removal and access to the pinion depth shims. Others may know, and I dont see why not but you probably could shim it like a dana and use what you have.
That's my problem. My kit didn't come with the pinion shim between the bearing and the housing. Mine is 101,000th. It was broken when I took the race out. The Crown part number for the shim between the bearing and the pinion (some units were shimmed this way) is 3205533K. I was hoping someone would know the part number for the larger shims that go between the bearing race and the housing. I looked at the post on the Jeep forum, the one they showed was 98,000ths. I know the new pinion will probably be different. I was hoping to find a shim kit for this application.
I thought I would start with the factory shim, I have an extra set of bearings I had honed at a machine shop so I can slide them on and off. I will check with Ratech.
That is correct, my install kit didn't come with the shims that fit my differential. Another member referred me to Ratech, they had them. I"m good now.
Won't need to slide the carrier or inner pinion bearing off once pressed on. Everything occurs between bearing and housing. Pinion inner bearing outside cone you will need an extra ground down... If you are going with shims vs crush sleeve will need an outer pinion bearing massaged as well. The write up on jeep forum, for me, gave a good explanation on how to determine where you will need to be from where you currently are with your old existing gear set.
