I'll check those out thank youHot, cold, any temp in between?
Fuel pump, fuel filter and filter orientation with appropriate return line (to rule out vapor lock) is where I'd check next. Then on to plugs, distributor, and timing.
I'll check them out, thank youWhat condition is your timing chain and sprockets in ? Mine were very worn and loose years ago and mine was doing the same. Ran ok until I pulled up to a light or stop sign and just die.
