Transmission Cover Panel
I almost ordered that one on FB, but in the time it took him to get back to me I had made my own. I have a Winters shifter and a custom T/C shifter on a 241 case…I didn’t put as many bends in mine- maybe only 6 or so- but it worked out great. I made mine out of some 14 Gauge IIRC. It is stout.
UPDATE
I couldn't bring myself to overpay for a pre-made tunnel cover, so I made my own. This is actually the second one I have made. I made the first one for my previous Scrambler. I did that one out of diamond plate aluminum and it turned out pretty well.
I didn't want to go with diamond plate for this one, so originally, I ordered a 12" x 18" sheet of flat aluminum. When I got that sheet, I quickly realized that it was going to be way too thick...it was 1/8" thick and far to rigid for what I wanted. I ended up making it out of 22 gauge steel, which was thinner than I wanted, but seems to be working out just fine. I might make another one at some point with some more suitable material.
Anyway, it turned out pretty good I think.
Here was the original...
Cardboard and tape template...
Cut out steel cover...
Installed. Still need to touch up the paint on it.
Pretty nice job. So what are you thinking as more suitable material ? I bought a nice used one that I cleaned up and painted and it came out well. Then I got the bright idea I would rebuild and twin stick. So with a new rebuilt different transmission and the twin stick the old or new one may not fit well. I might need to make one also.
I think I will find a good thickness and rigidity of aluminum to get a better look out of it. I rushed this one a bit because I wanted it done.
I also think the steel is a little too thin and it will be easily dented. I would also like to find a better boot set up. I had to move the twin sticks forward so they would clear the Lokar Shifter. I had bought both boots before I realized the final alignment of everything. I think I could find a three boot setup that would look cleaner.
