New but not so new
Looks like a great build. I have a buddy with a M170/military CJ6. It has long tall well wells (similar to yours) with little built in storage boxes. Have you considered adding storage areas to your wheel wells? Great place to put recovery gear and smaller spare parts.
My rig is officially alive and running good with the Holley terminator x. Monday the exhaust will be install and is the only outside fab work done. I will post more pictures tomorrow of the whole rig.
Finally finished 21 months to complete. turned out better than I could have expected. Had it on the Dino and it put 380hp to the rear wheels with stock f250 wheels. Runs great can’t wait to hit my local Johnson valley/ KOA trails to see if it crawls the big rocks.
I was wanting a clean dash so the only thing on it is the Holley 7” screen. All the lights, windshield wiper. Starter, blinker and heater are controlled by 2 eight switch Switch pros flush mounted on the center consol.
Such a beast of a build!
Are those full width '05 SD's or are they narrowed any? What wheels did you go with? How much backspacing? Hows the overall stickout?
I ask because I too intend on running '05 SD's, but I'm uncertain how they stack up to the body lines of the CJ, and it's hard to mine a good answer combing through builds. I'd like to maintain as close to majority tire coverage of a 12.50 or 13.50 with 6" flares. Contemplating cutting the long side and running an Ultimate60 long shaft for a ~67" WMS, then a 65" WMS 14-bolt or OBS Ford 10.25 rear.
Dirty life wheels
Overall front is 87” wide so basic the tire are completely outside of the body. 4.5“ backspace however I bought the wheels early in the build and I went with reid knuckles and went double shear on the full hydro steering and the high steer rubbed the tire so the front is 87” with 1/2” spacer instead of the 86“ we planned. The rear is 86”. When we built the jeepster I was dead set on keeping the tires under the Jeep and not cutting to much So we went with 44 rear axle out of rodeo and the front out of a wagoner. Now I prefer the full width stability . The jeepster started with 35“ now on 37” the scrambler is on 41.5.
in the end it is all about what you want to do with the rig and hope you don’t stray to far from the original idea. All the guys I wheel with told me LS and one tons. I didnt think I would wheel much harder than say the rubicon. Years later 6.0 one tons and im into the bigger rocks.
As far as cutting an axle I will say if I was to do it over I would have ordered Fusion axles. After all the work and up grades the cost would have been close enough to just buy. We installed 4 piston wilwood calipers on all four corners because the sterling calipers hang out so far and low from the wheel.
Dirty life wheels
Thanks for the response! You've mentioned some good points. Much appreciated.
