MomoJeep
- Seattle
- WA
I had my frame checked before building the Jeep. The said it was straight. However, for one of my motor mounts the rubber block is tweaked badly out of shape in order for it to fit. it seems the misalignment is like the engine it too far forward or backward, however, the other mount is ok. Could it be a bent motor mount bracket? Anyone one else seen this problem?
Also, one of my motor mounts recently started making a squeaking sound. I'm planning to check that all the bolts are tight, and wondering if anyone else has experienced this? It doesn't make noise when the engine is cold, but it does squeak when running either in gear or coasting. With the engine off, if I grab the valve cover and rock it back and forth, I can hear the squeak.
It may seem this is related to the misalignment, however, it was misaligned for years before the noise started.
Any thoughts?
Any thoughts?
