- Biloxi
- MS
One project gets picked up, another one gets dropped off!!
This is a "cautionary" tale of buying Jeeps site unseen. This was supposedly a rust free (spoiler alert, it is not) running (spoiler alert, it is not) 1985 Jeep CJ-7. JeepAddict bought it sight unseen, had it shipped to Baton Rouge.
The problems started when the transport company driver informed JeepAddict that this was a "non-runner". Upon it's arrival, Tommy could not get it started/running, either.
I went over last weekend, we got it "running" in the loosest sense of the word!!!
Multiple issues/clues:
Muffler exploded outward - suspect timing was messed with
Running super rich - exhaust burns your eyes, leaves black soot all over the ground
Newer fuel pump kicked the bucket, started leaking out the weep hole
Stinks like very old fuel
We got the Jeep running last weekend by installing a new fuel pump, filter, and blowing out the carburetor inlet with carb cleaner. It will idle, but it will not start up, and when you go to drive it, it just falls on its face, no power at all. Had to dribble gas down the carburetor for around one minute before it would finally run on its own. Or, key start it in gear for about 100 feet!!!!!!!!!!
The power steering was making God awful sounds, the fluid looked terrible. Drain and refill, much better. Coolant was low, oil was OK but needs to be changed. The brakes worked, BUT the master cylinder was empty, except for a layer of sludge on the bottom that I scooped out!!!!!! Will need to flush the brake sytem.
My aim with this one is to get it reliably running/driving. So, hopefully, it will not become a major project, famous last words!!!!!!!!!
Plan of attack:
rebuild carburetor
new valve cover gasket (current one shot)
drop fuel tank for inspection/removal of old gas (this thing stinks horribly of very old fuel, that is why it is staying outside!!!!!!!!)
a few belts/hoses
some fluid maintenance/inspections
new muffler/tail pipe
I already ordered some parts, so will start on this one fairly soon.
Kind of excited about this one, I have never worked on a 4 cylinder CJ-7!!
Basic run down:
1985 Base Model CJ-7
2.5L 4 cylinder
T5/Dana 300
Dana 30/AMC 20 axles with 4.10 gears!!!!!!
Power steering, manual brakes
15 gallon fuel tank
only around 75,000+/- miles
all original/intact emissions components under the hood, including the pulse air system
maybe original paint
the only "modification" appears to be the aftermarket wheels, so not too many prior owner "hacks"
This one has some rust. Not wide spread, but it has a few bad spots: top of both wheel wells where the roll bar feet sit, driver side "B" pillar on the exterior has rusted through, a few other areas I will mention when I find them. I only looked at this one briefly, but the frame appears great, and besides the definite rust spots, no wide spread cancer or coming apart at the seams.
Some new metal welded in, this could be a good one!!!!!!
I am seriously considering buying a MIG welder and learning how to weld sheet metal. If I had more time, this would be a good candidate. Who knows....
One last picture, my Red Scrambler got to move back inside the garage!!!!!!!!
That's it for now
Plan of attack:
rebuild carburetor
a few belts/hoses
Basic run down:
2.5L 4 cylinder
T5/Dana 300
15 gallon fuel tank
That's it for now
