This Jeep has the original exhaust system. The catalytic convertor, pulse air, all components look good, except for the muffler. This muffler was NOT rusty at all. I presume it blew up due to running overly rich/timing way out, cataclysmic back fire, blew it to pieces.
The muffler had the original clamp where it joined the catalytic converter (thank God), but the tail pipe was welded on to the other end of the muffler. Not sure if this is OEM, I always assumed all these parts were clamped together??
Anyway, I did not want to damage the catalytic converter, so I cut slits in the muffler tube, it slides over the cat. Bunch of cuts, hammer abd punch, got it off with no damage to catalytic converter.
Kind of looks like when Bugs Bunny plugs the end of a gun with a carrot LOL!!!!!
The rear tailpipe clamp came off, and I can reuse it. I cut the u-bolt at the catalytic converter, it was missing one nut, the other one was going to be a pain to get to, so cut the u-bolt off with the Dremel. The catalytic converter heat shield was loose on the back end, some damage, should be able to repair/reuse it. Can't leave it loose, it makes one hell of a racket rattling around down there!!!!
Temporarily hung the rear end of the catalytic converter up with the tailpipe clamp, prevent any damage to the rest of the exhaust system.
When you think about it, pretty amazing these parts came off/apart without much drama. I pictured the worst of the rust earlier, mainly the rollbar/exterior driver side "B" pillar. The rest of this Jeep is really clean.
Learned my lesson on my last project, dropped this gas tank out in the yard, and it only had about 2 gallons of fuel in it.
All of the clamps/nuts/bolts came off with no problems. No rust issues. Pretty sure this tank has never been removed from this Jeep.
I dumped the fuel out of the tank, actually looked clean, no rust or debris came out. Exterior of the tank/skid plate appear solid, too. Since it is down, I'll probably pull the sending unit, make sure no issues inside the tank, or with the pick up tube. Factory fuel gauge works, so I almost hate messing with it. Will probably pop the tank out the skid plate, clean up any rust, shoot some paint, IF needed.
Two more pictures of the under side of the tub.
Rear floor over the driveshaft is clean/dry/rust free. I'm not sure if this Jeep ever went off road, there is absolutely no mud/dirt/sand/scrapes/dents anywhere!!!
Bottom of the rear floor over the fuel tank, clean and dry:
Kind of interesting to note the factory primer color. Looks like the factory used a grey primer for Sebring Red. On Sherwood Green, factory used black primer. Makes sense, dark primer for dark color, light primer for brighter colors??
That's it for now
