Got me a set of YJ half doors, but they need work
wm69
Silver Member
God's Country
AR
Picked up a set of YJ doors over the weekend for my green CJ-7. $125 so the price was right, but they need some work.
Lock rod on the passenger door is missing, along with the rod from the outer door handle to the latch. Anyone make their own rods for these and if so what did you use? They don't seem to be available new anymore, and don't see any used on ebay. Doesn't look like it would be hard to make my own if I can figure out donor material that is able to be bent/ shaped, but won't bend under use.
Hinges also need to be adjusted. It's been awhile since I've done a door hinge adjustment, and the last time I did it I ended up stripping out several of the heads and having to drill them out. I don't want to do that again so I'm going to try heat. If I heat from the backside will it screw up the paint on the outside? Figured I'd use a MAPP gas torch on the bolts, and the doors aren't quite the right color, but the paint isn't in bad shape so I don't want to screw it up unless I have to. No way to access the bottom hinge bolts without cutting a hole in the inner door shell, so might have to heat those from the outside anyway (or use a hole saw to cut an access hole on the inner shell).
And of course, now I'll need Bestop upper doors to work with the Supertop and YJ door combination. Dang Bestop stuff has gone up a lot since I last bought anything!
I personally like to drive with no top or doors when it's warm, but the wife wanted half doors, and these popped up locally and were cheap so I grabbed them.
My CJ is medium green metallic, and the doors were dark hunter green metallic. I guess it's better than the bright blue set I almost grabbed a while back, but color still isn't quite right.
Is this where I justify getting the whole Jeep painted since the wife wanted half doors and everything needs to match?
If they aren't available it may be possible to get some for another model and cut/weld to fit.
At least some of the ends would be pre-bent and you know the material is designed for the task. :shrug:
Lock rod, on a half door?
I thought half doors were meant for topless summer drives.
Yeah, these half doors have locks. I doubt I'd ever use them, but I'm one of those "if it's on there it should work" people. OCD rears its ugly head once again.
And of course, I'm gonna have to drop $400 on Bestop uppers to match my Supertop
I can only lock and unlock with a key. I didn’t want someone maybe slicing through the uppers window, then reaching in and unlocking the door from the inside and opening the door and lifting the doors off and taking them, with them. So the rod is disconnected
That's actually really smart, so now I don't think I need that rod after all, and I'll probably be taking the driver side rod out as well!
Yeah I looked into trying to figure out how to keep the doors from being lifted also if the doors are not locked. If someone wants them, they are going to get them. Mine will take a little work and maybe some tools.
Don’t they normally have a little nut that tightens to hold them? You could emhance that type of “security”
I did that also, not a nut, but same idea, a tool will be needed to remove what I use, plus if I go on a trip, I have a SS cable I can fasten doors to body. Like I said, if they are wanted, knuckle heads will bring tools and defeat what you have
Yes, the pivot post has a threaded portion you put an acorn nut on.
YJ half door hinges.
I don’t know what this is called, but is screwed on really tight. Found it at the hardware store. 17AA3695-5305-4F7F-9DE2-2F6DCC4B605D.jpeg
Pics of doors. My passenger side inner handle came yesterday, along with a replacement lock set. The new lock set didn't have the little bit pictured, and since one of the locks was missing from the doors, I can't simply move the old one to the new lock cylinder. Anyone know what it's called or where I might get one?
I'll need to fab up a rod from the outer handle to the latch for the passenger door, get that little bit, and adjust the hinges and they should be good to go.
Think I'm going to unhook the inner lock rod on the driver's door (passenger door rod was missing) like Belezeit where I can lock them and no one can walk off with them.
Had to put a little into these but for $125 plus the odds and ends I think I did ok.
You got a bargain. They were hard to find around here and needed repainting. Cheapest thing was $15 for rekey, and $15 for straps to keep them ( doors ) from flying open and slamming the front fender area.
Got the hinge bolts loosened up today, so tomorrow I’ll get them aligned.
Latches soaked in my parts washer and work great now, but I figure they need some lubricant of some sort on them.
What’s the best thing to use that won’t gum them up again when the dust hits them or it gets cold again?
Used this video yesterday and got the passenger door very well aligned.
The driver's door doesn't want to close all the way. It will latch, but not close enough to let the latch completely encircle the pin. That's going to need some additional work, but putting a hammer on the bolt, and then smacking the hammer with a bigger hammer worked with no stripped out torx heads, so that was a huge relief!
I also managed to fab up a rod for the passenger side outer door handle. I used one of the wire frames that the political signs go on for the upcoming local elections came on. People keep putting them up on the empty lot at the end of the street (that I own) without permission, so I keep taking them down and throwing them away, but one of the metal frames for the small signs was the perfect size wire to bend my own rods out of using my vice and a big hammer (and using the driver's door rods as reference). I guess politicians are good for something after all...…...
Ordered a couple of rod clips to replace ones that were missing.
Anybody have a source for that little bit that the lock cylinder rod attaches to? I think I've got everything else I need for these doors.
Update on these doors.
Got the passenger side fit and latching perfectly. Can't get the driver's side to close all the way (where the latch fully closes around the pin), but it closes "CJ factory" enough on the pin, doesn't rattle, looks good, and my CJ full steel door is about the same, so I'm going to live with it.
The rod I made from political sign frame still works great.
I bought a lock lever for a full door lock, which was angled much differently than the short and straight half door lock. Put it in my vice to flatten it out, drilled a hole for the rod using the other side as a template, and ground off the excess. Works fine.
Now I just need to SEM the door panels with Camel SEM to match my Honey interior, and then get the doors painted to match my Medium Green Metallic paint (whole Jeep needs to be painted)
