- God's Country
- AR
Picked up a set of YJ doors over the weekend for my green CJ-7. $125 so the price was right, but they need some work.
Lock rod on the passenger door is missing, along with the rod from the outer door handle to the latch. Anyone make their own rods for these and if so what did you use? They don't seem to be available new anymore, and don't see any used on ebay. Doesn't look like it would be hard to make my own if I can figure out donor material that is able to be bent/ shaped, but won't bend under use.
Hinges also need to be adjusted. It's been awhile since I've done a door hinge adjustment, and the last time I did it I ended up stripping out several of the heads and having to drill them out. I don't want to do that again so I'm going to try heat. If I heat from the backside will it screw up the paint on the outside? Figured I'd use a MAPP gas torch on the bolts, and the doors aren't quite the right color, but the paint isn't in bad shape so I don't want to screw it up unless I have to. No way to access the bottom hinge bolts without cutting a hole in the inner door shell, so might have to heat those from the outside anyway (or use a hole saw to cut an access hole on the inner shell).
And of course, now I'll need Bestop upper doors to work with the Supertop and YJ door combination. Dang Bestop stuff has gone up a lot since I last bought anything!
I personally like to drive with no top or doors when it's warm, but the wife wanted half doors, and these popped up locally and were cheap so I grabbed them.
My CJ is medium green metallic, and the doors were dark hunter green metallic. I guess it's better than the bright blue set I almost grabbed a while back, but color still isn't quite right.
Is this where I justify getting the whole Jeep painted since the wife wanted half doors and everything needs to match?
