The writeups you guys created REALLY helped me with the fresh air and heater box rebuilds.
I also did the Blazer blower motor upgrade. Made a huge difference in air volume.
Got everything mounted up:
Did a quick test fit of the custom dashboard. Needed to make sure the gauge layout didn't hit the ducting. It was close but it worked.
I have a Double D Fab dashboard. I came up with the layout. I wanted to move the passenger speaker to the outside so it would be behind the roll cage down bar. And I will be able to open the Tuffy glove box in the new position:
Put some Kicker speakers in. Had to space them out to prevent the cones from hitting the dashboard face.
I'll be running this Fusion Media Player. It is a Marine radio and will live in the Tuffy Center Console. Wanted to see how the speakers sounded and get them spaced back from the dash properly. They sound pretty good. I will be putting two in a soundbar as well and maybe a power amp to get them more juice. I got the Tuffy Console and Glove Box keyed the same as the under seat storage for the back seat that I already had. Gotta keep the key count down.
The Fusion has Bluetooth of course and I love the big volume knob, and easy to read and press buttons. 90% of the time all I need is volume, play/pause and next track. This unit makes that easy to see and hit while on a bumpy trail.
I also test fit the Midland MXT-275 GMRS radio to the side of the Tuffy glove box. This unit has all controls and a speaker in the handset. You can actually turn on both speakers - the one on the handset and the one on the unit. It was pretty loud which is great.
And I can still drop it out the bottom if I need to.
