Changes in latitudes, changes in attitudes
I know about cleanup. 8-10 years ago a medium size house one went off at about 1 am in the garage. Went everywhere, but seemed like the dust was only about 3 ft high and not on anything above that, and the Jeep was spared. Was quite the clean up though.
I have a couple of Halon extinguishers. They are actually many years old, but it seems that because of it’s composition it does not have an expiration date. I have used one in the past on a burning motorcycle, and it put the gas/plastic fire right out.
Helpful, thanks… How many lbs did you use? I see there is a 1 lbs, 2.5 lbs and 5lbs
I have the 2.5lb units. On the motorcycle accident, I used about half of a 2.5 LB. But once you crack it open it has to be recharged/replaced. It says the 2.5LB sprays for appx. 9 seconds. The motorcycle fire took probably 3-4 seconds to extinguish. I used to get them for next to nothing when I was managing PepBoys back in the early 90’s.
Back in 2005 we got a new F650. Very first day the dry chemical fire extinguisher went off when I sat in it for the very first time. I adjusted the seat and set the thing off. It had no safety pin in it. What a mess and it doesn't taste good either. Boss was passed, not my fault thankfully. He sold the truck last week with 92,000 miles for $30k, paid $48k for it in 2005.
I’ve seen those before. Have you ever used one? The ads look promising-
I have not used it. Read some reviews and watched a bunch of online videos. Seemed like a good option. Tempted to test it, but haven’t yet.
UDPATE
Added a Bluetooth OBD2 Scanner to monitor engine vitals on iPhone. Easy hide under dash for clean look, a few screenshots and link
LINK: https://www.amazon.com/gp/aw/d/B07J51W9NS?psc=1&ref=ppx_pop_mob_b_asin_title
It will be Interesting to hear how that works. I had a ScanGauge and it was pretty good. In my Silverado I have a Pioneer head unit that links in through iData Maestro and gives 2 pages of data on the display. But I don’t think a double din head unit is on tap for my Scrambler- so this might be an option.
@Randyzzz I have Speedhut gauges which is good for MPH, GPS accurate, and RPM. The temperature is one I want to watch closely to make sure the Hemi is staying cool… so far, normal operating temperatures even on 95 degree days, running AC… over time and miles I will monitor less so for $62 was a wise investment.
I’m running Speedhut gauges in my Scrambler too. I caused myself a load of headaches installing a larger than stock radiator, so I hope it’s worth it to keep the 6.0 cool.
Finally… I ordered these on 2/28/2022 and got today. I was going to get in July but major shipper lost them. Company filed claim and made a new set, so I only lost time and appreciate their attention to matter. Seem to be solid, will require some customization to fit the TDK Hybrid frame, not a surprise.
Talk about full coverage - like how they go to the flare
UPDATE
Needed a new battery and installed the Odyssey Group 34 by removing the rear tray bracket. I am planning to install a switch pro panel for lockers, etc so I will be removing the relays and changing terminals for the winch hook ups. More changes to come…
