MomoJeep
- Seattle
- WA
(1) For a long time, I've been thinking of the 5th gear in a 5-speed manual as the "top gear". In other words, the gear to use at your highest speeds. Also, on the Novak website, they talk about "gear span". On other words, it's not how low your lowest gear is, but how big is the span from lowest to highest Then combine that with the right axle ratio). This implies you would use 5th like any other gear, but at your highest speeds.
(2) However, I have also heard of "overdrive" as the gear you shift into when you are *already* at top speed, but to drop the rpm's (and lower the torque) for fuel efficiency while cruising down the freeway.
So with that said, when I'm looking at dropping my axle ratio's, and want to figure out my top speed cruising rpm's, should I do the math for 4th gear (and treat 5th as in (2) above, a bonus gear not for higher speeds, but to lower rpm's at the same top speed. Or should I treat it as in (1) above, a gear to use like any other to reach higher speeds?
