Chamba
Not obsessed: focused.
- Vero Beach
- FL
This could be perfect for an XJ fan
Personally do not like the pre-97 look but it looks solid.
It’s a lot better than I thought it was going to be when I went to look at it. The main “frame” channels are really good. The rockers and the substructure around the rear upper shock mounts are the worst, easily. But the PO had added a set of the “Y” replacement captured nuts for the upper shock mounts and installed a set of bar pin eliminators already.Just looking at that picture of the underside of your XJ is giving me palpitations. I'm going to have nightmares now; it's like Jeep torture.
What up with that sweet TJ in the parking lot from the picture above![]()
Good use of it but that's not what Jeep designed it for, though. I've always thought that it's like the designers started that panel and then forgot to finish it out before it went into production.That cubby is for a JL audio stealth sub box(if you are into that kinda thing). I had 2 but never installed either. Now I have 2 10" subs under the rear seat of my Ram.
You can see where I cleaned off some of the muffler before finally giving up on it, and the underbody above the driveshaft got a bit of a wipedown.)
New tires were too much to swallow around the holidays and I haven't seen anything good on marketplace that I could get to reasonably. One good deal, but I was out of town when I saw it
Oh HELL to the NO!Send me your Birddogs! Love the look of them!
