- W-S
- NC
I always squeeze the trigger just above/near my cut so that the plasma stream is going then plunge in to cutting. I have the same machine and have cut 1/4" all day on a tip.
That works as long as your machine has the auto arc feature. If your machine needs the ground path through the work to start arc You must be close, but not touching it to strike the arc. Some machines require you to lightly scratch the metal with the tip to start the arc.I always squeeze the trigger just above/near my cut so that the plasma stream is going then plunge in to cutting. I have the same machine and have cut 1/4" all day on a tip.
I’ve heard of going to crazy measures to get things done but man! If you needed the t-case that badly drop it from underneath!!OK... so I did some playing around and things are cutting a lot better.
New tip, removed the drag cover and put on the smaller one and now just free handed it.
I used the grinder to get a really good ground closer to the cutting area.
I purged the air tank for any traces of water as well.
Once that was done, it was great... until I touched the tip to the cutting area and it clogged/blew out the hole.
So a new tip and then we were in business.
Downside is that now I have no more tips... so ordered some more up.
It also really needs high air pressure... which is fine, but a lot of the research I did shows lower pressure for these machines.
Pic isn't great (very smokey conditions last night), but you can see how the cuts are and how it sliced... there was NO air movement last night.
Almost creepy. Desperately need a fan when you do this... had to wait for a while for it all to dissipate... very smoky.
Anyway, the AX-15 has the adapter plate (glued) onto the D300 with some grey RTV that I have never seen before.
It did NOT want to come off, but finally got it removed.
All in all, I am seeing the finish, most of the heavy plate welded junk is gone and I don't have a ton left.
Or they didn’t want it to leak any fluidGuess they never wanted to come apart, that’s a mess… maybe acetone or airplane stripper will help in getting off…
They find me and me them... like an 85 i may have picked up today...There's a honey pot up there somewhere...........Do you find them or do they find you?
I bet it looks like a scene from Star Wars when you plasma cut one of this apart! Rock on cowboy!
Now are you braggin' or making excuses? Either way you're getting it done!They find me and me them... like an 85 i may have picked up today...
40x40 and a 15 ft. ceiling... one garage door which is 12x14 roughly.To continue the off topic for a minute...
what are the floor dimensions and ceiling height?
Off topic - is your building stick built, pole building, engineered? What's your concrete pad thickness? Do anything differently now that you're in it?
Thx!
1985 Jumped on the trailer yesterdayThere's a honey pot up there somewhere...........Do you find them or do they find you?
