- Centennial
- CO
Trying to figure out why the brake warning light turns on when I press the brake pedal and turns off when I step off. I can lightly press the brakes and the rear lights will click on then with a little more pressure when I use a test light at the switch the switch will ground out. Fluid level is fine and brakes have been bled numerous times. New painless wiring and speed hut gauges. I called them both and they both believed it was a ground providing feedback to the switch. The emergency brake works normal.
Maybe the switch is doing what is should but how do I fix it?
