- Richmond
- TX
If the insulation is cracked I would sleeve it with a layer of heat shrink tubing. There is already an additional layer where the wire goes into the heater and when I took one apart, I did not see where the heater was likely to fail with deteriorated insulation.It was single digits last week. Doesn't happen often but when it does why not be prepared. It's already there just need to repair the wiring.
The one broken in pieces was destroyed from trying to pry it out of an intake. Best way to remove it is gently tap it out from the carb throat side. The carbon locks them into the intake and makes it hard to remove them.
