81 CJ 258 Sniper/Hyperspark install review/questions
It was single digits last week. Doesn't happen often but when it does why not be prepared. It's already there just need to repair the wiring.
If the insulation is cracked I would sleeve it with a layer of heat shrink tubing. There is already an additional layer where the wire goes into the heater and when I took one apart, I did not see where the heater was likely to fail with deteriorated insulation.
The one broken in pieces was destroyed from trying to pry it out of an intake. Best way to remove it is gently tap it out from the carb throat side. The carbon locks them into the intake and makes it hard to remove them.
For more detailed info on the under hood stuff;
I think this is the updated location for this (now defunct) site http://dale02.home.sprynet.com/home.htm
Here is the page discussing the manifold heater http://gleebledorf.com/manifold.html
Vacuum hose diagram http://gleebledorf.com/vacuhose.html
I used this sire when deciding how to customize my installation.
@ag4ever Thanks for the link, I'm trying to rebuild my library after the loss of my hard drive.
At least some of it got loaded and saved here after this site was redone. (y)
