- North Dighton
- MA
Many thanks Rob! Raymond sets that bar high, I can only hope to do half the job he does.Awesome garage combo! Very cool. And that bolt above the crossmember does look like a huge pain in the azz. Great write-up.
Many thanks for the insights, especially the oil wick/oil behind the pilot bushing. I was leaning towards the Fel-Pro one piece oil pan gasket before you mentioned it, so will probably go with that one.Verify if it is transmission/transfer case fluid or engine oil dripping off the transmission mount. Since the transmission/transfer case are already on the floor, I would change the Dana 300 input shaft seal AND the T5 output shaft seal. The T5 seal should not be leaking since it is new, but who knows.
On the engine, I would go with the oil pan gasket. I was careful when I picked up/transported/installed the engine, but the previous owner, maybe not? I have had good luck with the Fel-Pro one piece pan gaskets, just pay attention to where they tell you to put the small dabs of RTV in the corners
Glad it wasn't the transmission leaking, well, at least for now, let us know what you find
Put an oil wick/some oil behind that pilot bushing before reinstalling the transmission
Around post #662:
Another hour tonight, just about ready to pull: both shifter, transmission/Dana 300 to skid plate bolts, six frame bolts loosened up, clutch linkage and boot, reverse light and 4wd light harness plugs disconnected. For my future reference, skid plate to frame bolt locations: That's it for...www.cj-8.com
Found a definitive source of a leak on the transmission last night. Removed the bellhousing, and found oil coating the interface with the transmission. I was surprised because I didn't suspect oil was coming from this location at all.
The culprit on the transmission side...
I was hoping to not have to get into the transmission, but that looks to be the case now.
The back of the engine was dry overnight. Will put back on the flywheel, bell housing and starter. I will run the engine, then remove all this again and check for leaks.
Will do that Raymond and report back.Looking at the picture of the face of the bell housing that goes up against the face of the transmission, I see oil up high and around the perimeter. I would bet that is motor oil. The damp spot on the front of the transmission, in the front countershaft bearing location, is probably not from inside the transmission, but oil just collecting there. That lower bearing has sleeve retainer all around it, and is a press fit. Could be a leak, but doubtful.
Wipe off the face of the transmission really good. Let it sit for a day or two with the input shaft pointing slightly down. See if the oil comes back. Also, check around the front bearing retainer. It is sealed with RTV to the front case, could be a leak here?
Valvoline MTL IIRC.Running gear oil or ATF in the transmission?
Personally, I would suspect a valve cover gasket leak. It will only leak while the engine runs.
Sorry for your troubles, plastic covers are prone to leaking or crack as torque spec is very low…Well, now I am feeling completely baffled and frustrated. Let the jeep sit all week. Went to check that there were no oil leaks from anywhere other than where I suspected at the RMS. Put my hand on the back of the engine where the top of the bellhousing mounts and there is oil there. So much so it dripped down along the drivers side, off the ear of the engine and soaked the exhaust. I looked/felt the back of the valve cover area, it was a little moist, but no true source of oil leak found. The engine is painted black which makes finding these leaks a bit harder. I suspect the plastic valve cover is leaking near the firewall. Just a guess. Open to any other suggestions, but I am baffled. Right now it appears I'm doing a valve cover reseal (and probably a metal cover over plastic), rear main seal, and oil plan gasket.
I was looking for his thread on that but haven't found it yet.Clean the engine, toss some flour on it, see where the wet spots are.
But yeah, if you have a plastic valve cover, replace it. Raymond has a great how-to somewhere around here on the valve cover to keep them from leaking.
Here ya go!I was looking for his thread on that but haven't found it yet.
