I would say no on both counts, personally. Would have to be a rig that never sees rain/water IMO (like my Cherokee)Worried about moisture getting under both…is one better than the other?
After seeing what moisture under the carpet did to mine, I would say no. And really, how quiet is a CJ ever going to be?
On an unrelated note, what motor mounts are those?
| MMCJ-G3 | Kit MMCJ-G3, engine mounts, GM Gen III engines to 1976-1986 CJ Jeeps, bolt-in or weld-in style, prep |
If you're still in CA, I would think the weather there may have a lot to do with lack of moisture issues.I used Dynamat on the front of the engine firewall, the inside of the cab to the rear and the Postal top. I have carpet on top of that and there is very little road noise and engine noise even with the Hemi in it. For moisture, I did coat everything with POR15 before I put it in. I have no issues with rust or moisture years later.
