quality heater core replacement?
GrantP
PHOENIX
AZ
Hello - I've been a member for a while after I finally got my Scrambler running again but never posted. I've owned it since 95 or so and it has sat in my garage most of it's life. Anyway, in the last 4 years that it's been back on the road I've gone through 3 heater cores. The first failure was the original so that was not a surprise, the other two were/are OSC brand from RockAuto with a "Lifetime" warranty.
Turns out, "Lifetime" is a misnomer. Since I've already claimed a warranty replacement once, Rock Auto will not allow me to claim another. All they are offering is a refund for the second bad heater core. "Since there have been multiple failures of this product we cannot send a replacement as we cannot guarantee you won't have another failure" or something to that effect. By that logic, "Lifetime" replacement means "We'll replace it once". The upside of this is that now I'm free to choose another brand with my refunded money, the question is which brand? I won't touch Omix or Crown if I can help it.
I've checked for electrolysis as a potential problem but the highest reading I can get is 0.03 volts, I've read upper limits of 0.3 to 0.4 so I'm at least 10x under the limit.
Any brand suggestions are appreciated, thanks!
I have gotten two from Carquest (the premium option) without any issue. The only reason I needed to replace the 1st non original one is I pulled on the heater hoses too hard when doing my motor swap and cracked where the pipes met the core. That one lasted 10 years. I am hoping this one does as well. Two years and counting now.
For what it's worth, I always cary a short 3 1/2" piece of pipe in my tool box for linking to two heater hose ends at the firewall when I discover coolant on the passenger floor. Both my Jeeps seem to rattle the cheep sodder connector(s) on the heater cores frequently. It's a quick fix on the trail and minimizes the loss of coolant.
I've amazingly had good luck with the crappy aluminum cores from NAPA and O'Reilly. Not sure if anyone makes a quality copper/brass core like OEM. I keep a plastic pipe in the console, just in case.
Carry a brass hose splice for that same reason.
I have an aluminum one.........I don't remember where I got it, most likely Autozone, but nothing special. It's been in there for 11 years, Between the aluminum fast heat transfer and the Blazer fan, cranks out a TON of heat.
