Help needed!!
Srdjan
New member
Valdivia
LR
Hi everyone! Srdjan here from Chile, I’d like to know if any of you have ever extended a YJ hardtop—or know how to do it, or know someone who has—to make it fit a CJ8 Scrambler? Any help would be extremely useful.
Thanks a lot in advance!
I know it has been done. I have seen a few nice, and a few horrible jobs. You would want to use an earlier YJ top(or at least the back top if melding 2 together) with a "T" handle on the hatch like a CJ7 top. Later YJ's use the tailgate to keep the hatch closed.
I'm actually in the process to figure out how to do it, but my initial plan is to cut my 1987 hard top, just in the middle of the side windows, and then build the missing part with the propper plastic and fiberglass. So I'll keep the rear hatch functional.
The hardtop on my Jeep was actually two CJ-7 tops. You could theoretically do with with a couple YJ tops too, but issue is the window top edge is slightly curved, and the two halves won't line up right.
To combine to CJ7 tops, you'd cut one at the back of the window, and cut the other at the front of the window. Then stick the long front and the long backs together with a big fiberglass band-aid. Making sure it has to be enough to get you 24.5" of additional length.
The problem with extending a YJ top is the way the side windows arc. You'd need to do more fiberglass work, basically creating a new window channel at the top, and have custom glass made (you have to do that anyway). Alternatively, you could cut just one top in half, then make a new center section with fiberglass mat to give you the 24.5" extension. You will also need to either make sill extensions from scratch, as well as filling in the window frame gap, or find another YJ top to scavenge from. This is going to result in two joints instead of one though, and will not be as strong.
It might also be possible to cut the YJ top in front of, or behind the side windows, and just fill in the new area with a mat panel. Then the window would either be at the front or rear. Privacy top? Either way you slice it, there's a lot of fiberglass work. If you are not experienced in fiberglass, it's not a project I recommend.
Hello, and thank you very much for your feedback. Actually, what I intend to do is exactly what you suggested as a second option: cutting the YJ hardtop right through the middle of the rear window and—with the help of a specialist—fabricating the missing section. This would allow me to create straighter lines in the area where the side windows are mounted. I plan to replace the side windows with custom-made, high-strength acrylic panels that feature a UV filter on both sides; I chose acrylic because it can be heat-formed to achieve the necessary curvature to fit the window openings. Best regards, and thank you very much from Chile!!...
This is how I hope my project will look when it’s finished.
OH nice, another one of those YJ-L's, or is it L-YJ? el YJ? hah... I've never seen a real one in person. I had to make mine with a bunch of cutting and welding. 😉
Hi, my jeep is a AIL (Automitive Industries Limited) Storm M-240, a military jeep built in Israel and based on the jeep wrangler YJ. The YJ and the Storm are almost identical, but the storm has the exact lenght of a jeep cj8 scrambler.
That is quite a project to cut in half and fabricate the center section. I like the lower side windows like you've drawn on the Orange picture. Might want to make a sheet metal section with the complete opening for the window and fiberglass that in place on each side and then add a metal center section to connect the sides. That would make a good base for your fiberglass and you could probably use flat glass if you wanted. Vinyl covered tops were popular in the past. Some cover the complete top. Some covered the back half of the top. You could cover the edge with a mounding anywhere you want it to stop. Some thin closed cell foam under the vinyl would smooth out a lot. The underside could be covered with thin carpet like the new CJ-8 hardtops, or use the foam backed headliner cloth. I've got an extra full CJ-8 hardtop in my garage. Too bad you are so far away. You'll get a lot of satisfaction once all the work is completed, especially since materials are more difficult to obtain where you are. Go for it!
Thanks for your comments Kim, since I'm still in the process to define the "how to", all comments and advices are very helpful in order to clarify some aspects on that build.
Thanks again, and I'll post pictures of the complete process as it goes on.
Welcome and interested in watching this happen! Fixed the typo in the thread title.
Yup, I'm familiar with the M240. As far as I know, only South/Latin America and Middle East ever actually got them. You might see one in the US sometimes, but not often, usually a custom-made job by the owner. Once in a while someone might import one from Mexico, but I don't know how often that happens.
I'm definitely curious to see the progress of this hardtop modification.
The Chilean Army purchased and fielded the Storm M-240 starting in the early 1990s, employing them as light tactical vehicles. Some were equipped with a 106mm recoilless rifle, others served as tactical ambulances, and some functioned as light troop transports. Late last year, these vehicles were finally auctioned off; that’s when I decided to strip down my Wrangler YJ and use many of its parts to transform the Storm into a "SCRANGLER"—my own version of a YJ-8. I’ll be posting photos as the project progresses! The picture is from the day I got them to the shop for stripping down
