It’s referred to as swaybar flip, the rotation gains a few inches. Remove a bolt and rotate swaybar motor, tap, add new bolt. The factory bumper has a lower skid to protect the swaybar motor. This modification allow that skid to be removed or use a tight clearance front number.What was the tap on the hole in the swaybar disconnect for? Bumper pick up that hole?
I used one of the switches as Power switch, enabled “auto shut off” timer and it has a low voltage cutoff. I may add on final battery a master cut off.Is there a physical on/off switch for the switch pros? I have another vendor’s Bluetooth switch setup on my camp trailer and found that it occasionally would turn lights on by itself during the night. I added a power switch to the feed to it to turn it “fully” off. I figure it something specific to the one I have but just an fyi.
Thank youBeautiful work. Practical build. Nice job!
Thank you, we should do a Carolina CJ8 meet up…That's a toolbox full of skills you got there. Pretty handy! Looks great and hope to see it in person someday.
