1979 CJ7 Brake Issue
frankai123
New member
Christiansted
VI
My CJ7 brake lights are not working. Here is everything I have done.
1. Fuse is good.
2. Power is getting to the brake switch.
3. Brake switch is good. Checked itby ohms check. All is good.
4. Turn Signal switch in the column was broken so I replaced it.
5. Bulbs in tail light assembly are good.
The Blinkers are working fine and the tail light are working fine as well but I am still not getting brake lights.
Any help for a new Jeep guy would be greatly appreciated.
Ok- so turn signals and brake lamps share the same wiring and filaments from the turn signal switch back. The first place I would check is the brake switch output. There should always be power to the feed side of the brake switch, and power on the output side when the brake pedal is depressed. This wire should be Pink, at the bottom of the connector strip for the turn signal.
If the pedal is depressed and there is power at the pink wire on the turn signal switch strip, then the problem has to be in the turn signal switch. If there’s no power with the pedal depressed, it is either in the brake switch or in the wire from the brake switch to the turn signal switch.
There’s two pink wires on the turn signal switch connector. The one you’re checking is the one at the outer end, not in the middle. Circuit 65image.jpg
1. Fuse is good.
When did the issue start, before or after the TSS (multifunction switch) was replaced?
The brake lights route through the turn signal switch assembly and use the same wiring that feeds the turn signals.
If the rear turn signals function properly then it would indicate a problem with the brake switch power getting to the switch or the switch itself. It's very possible that it's simply a loose or poor connection in the wiring between the brake switch and the connector on the column.
If you get brake switch controlled power (on and off depending on the brake pedal position) to the "P" terminal (pink wire) then the issue would be between that connector and the TSS or the TSS itself.
There’s two pink wires on the turn signal switch connector. The one you’re checking is the one at the outer end, not in the middle. Circuit 65View attachment 102583
I need to learn to type faster. :rolleyes: :thumbsup:
Members helping another member within 2 hours on a Saturday night posting 7 minutes apart is one of the many reasons why I love this forum and enjoy my Sunday morning coffee that much more.
Appreciate all the posts. As far as I can tell, the brake switch ohms out at 0 when the pedal is pressed so I am assuming the switch is good. There is power going into the connector (when disconnected) for the switch but haven't connected it up to see if it is passing through.
There was a problem with the brake lights before I changed the TSS. I did some research on the TSS part that Napa sold me and one web site says it is not compatible. I ordered a different one and will install that later this week when it gets in.
I plan on playing around more with it tomorrow afternoon when I get off work. Hopefully it is not the brake switch playing games with me. It takes me 5 days every time I need to order a new part.
So, after installing the new turn signal switch I found the connection going from the vehicle plug to the TSS plug was bad. I cleaned and tightened the socket and now the turn signals and brake lights are working.
New problem though, when I turn on the headlights, the right turn signal lights stop working. The left turn signal continues to work, both brake lights continue to work but the right turn signal stops working.
Check all your grounds in that circuit.
I have checked the ground from the tail light assembly, the ground for the head/tail lights and the ground for the wiring harness. Checked them, cleaned them and checked them again. My right blinker light still will not blink. The brake light still works but not the right blinker
Change both right front turn signal bulbs, one may be bad (fender flare and grill bulb).
So it sounds like the right blinker is using the running light circuit as a ground. I can’t see how this problem didn’t exist before this whole issue. The running light circuit is independent of the brake/turn circuit. Got me stumped. My mind says there’s an obvious solution…but I can’t think of it right now.
Make sure the bulbs are indexed properly in the sockets. The dual filament bulbs have a low pin and a tall pin. If you get the bulb “clocked” too far, or not far enough, that might happen. Also check all the sockets on the affected side for corrosion or frayed wires. Front and rear.
