Almost no rain tonight, so pushed it outside and fired it up. It starts and runs OK, BUT the timing at idle, with the vacuum advance hooked up, was only 8 degrees advanced, so severely retarded.
But, I could not advance it any further due to the distributor's vacuum advance nipple hitting the block:
So, I pulled the spark plugs, turned the engine over by hand to TDC everything:
And reset the distributor like so, rotor pointing at #1 on the cap:
Now, I can advance the timing to my hearts content!!!!
I have not adjusted the carburetor idle mixture yet, but judging by the new plugs/exhaust smell, I'd say it is running a hair rich!!!!
The carburetor that is currently installed is a made in China eBay "new" Carter BBD. It runs decent, so I won't outright condemn it until I try to tune it. I have the original carburetor in a box, I can always try to rebuild it and install it IF I run into issues with the current carburetor.
Not the best pictures, but went on a 20 minute test drive. Not too cold, around 50 degrees, so not terrible!!!
Some stop and go, worked up and down through all the gears, got it up to around 55mph. Drives and runs really well. Brakes, clutch, steering, everything is pretty good and tight. I would put money on it having 3.31 axle gears, seeing how it behaves like my green Scrambler with 3.31 gears and 31" tires. Engine is nice and smooth, no odd noises, pulls hard. It will brake the ass end loose in 2nd on a wet road, but I wouldn't know anything about that!!!!
So, a few more issues to address, then to Baton Rouge:
1) install new heater core/blower motor non-op
2) check rear axle bearings, replace if needed
3) drain and refill T5, reinstall floor plate/boots
4) fix windshield wipers
5) a bit more carburetor tuning
That's it for now
