robertlewisnet
- Jackson
- MS
Great. Next time I plan on being down there I'll be a calling!
Dennis- will your WIFI diag check for speed sensor signal? Might be somewhere to start. In high range the VSS signal is the same if it's in the tailhousing or in the adapter. It's only only in low range that things get weird. With the sensor in your position (Stock), you just need to tell the computer when you're in low range- there should be a wire that gets grounded IIRC. Hopefully there was a tone ring installed on the JB output shaft...
Imagine that- a new part that's bad. Glad the overheating was that easy to figure out.
A very good point that I will check out. I am also questioning if I may have the wrong VSS. When I installed the JB Conversions SYE the VSS bushing was a totally different size one than the one Painless recommended with their harness. So I went with the one from JB instead of Painless. At Least now I have a starting point.I just thought of another thing to look at. Make sure that your shifter ranging is correct and not allowing it to be between two gear shift detents at the transmission.
Sent from my SM-G920V
Yes they are. So they both should be doing the same thing?They are both 2 wire sensors right?
After looking at your pics, you need some of these gates hoses-
28472 is the 5/8" hose
