Sweet Lord Jesus it shifts in all 4 gears now. Oh that's sweet. Wait, I have to back the TC off again to fix a oil leak, I guess I messed up the gasket. That's a piece of cake after everything else I have done.
For all the nay sayers who didn't think this combination would work with the 2:73 differential, well it will shift into Overdrive as slow as 35 MPH if you want it to and it will still smoke the 30" tires from a rolling start. I think I'll probably leave it just like it is.
You know there will be a video later.
I hope I don't count as one as I thought you were going with bigger tires and as you've said you have no hills either. Regardless very happy for you and anxiously awaiting the video [emoji106]
Did I actually say I might leave it like it is. I think by now most members know me better than that, I can never leave well enough alone. In fact I'm already thinking about what Stump Jumper could do with 3:73 gearing. More CHA-CHING....... well it will shift into Overdrive as slow as 35 MPH if you want it to and it will still smoke the 30" tires from a rolling start. I think I'll probably leave it just like it is.
. I'm also looking to install something similar to a Scan gauge in the dash for some real time diagnostics. I'm open to suggestions.
They work good. I should have one showing up today for the 6.2L TJ that I'm building at work.They work good. I should have one showing up today for the 6.2L TJ that I'm building at work.
