- Dexter
- MI
Finally got the tow truck there today to pick it up.
I'm kinda a photo whore so I will take as many as possible and post them for your enjoyment.
My man!!! Right on!
A set of JK Axles from Mopar performance for $2500 total might be a good idea??
Were there any D44's in any CJ's that could be swapped into this to get rid of the AMC20 rear?
I think the carpet was stock. Mine had it as well, same adhesive. The other one that the guy I bought mine from had it too.
On the JK axles, obviously they're set up for a JK suspension. Anything can be made to work, but you're getting into cutting all that bracketry off the axles to weld on spring perches or fabricating a coil/arm suspension. Other question is the differential location. I think the front axle pumpkin will be on the wrong side, so you'll be looking at a different transfer case to change the output side.
Why is it leaning so much (or appearing to) on the tow truck? Is the left rear tire flat? Or is it just sitting in a strange way?
You are correct about the transfer case. If I switched to JK Rubi 44's I would clock the 300 ( I have to buy an adapter plate anyhow for the AW4 so clocking it then would not be that big a deal.
Behind a 6cyl though, I dont have any problems with the chain drive design of the 231, and I just happen to have a 23 spline one with an SYE on it that I fully remanufactured that is essentally brand new sitting on my parts shelf so it would "Free" and I could get some $$$ out of the D300.
I need to try and find out some more info on this Jeep its history. I'd like to find out exactly where in Alaska it was driven and if it was carrier owned or postal service owned.
One other thing is what about the extra heater?? Where was it at?? I got a goofie looking heater thingy that is in 2 pieces but I dont know what it is??
If I put a YJ front clip on this and got HIP2BSQ for a license plate would that be cool or not??
They are half flat/dry rotten, and the rear springs are not in very good shape.
Nothing is bent or damaged or out of whack causing it to sit that way, just the springs are messed up a little.
