- Biloxi
- MS
Ok, to the best of my knowledge, and after experimentation, the damaged piece below is indeed the choke relay for the AMC 2.5:
The plug from the wire harness that plugs into the relay:
The contacts are dirty/slight corrosion, so I popped each one out, one at a time, and hit them with some sand paper:
My notes:
On the 258, their is an oil pressure switch that ties into the choke relay. On the AMC 2.5, no oil pressure switch. So, the brown wire from the alternator is what tells the relay to open, an allow battery voltage to flow to the choke. Both accomplish the same thing: IF the engine is not running (either via oil pressure present or alternator spinning/charging), the relay will NOT open. In this way, IF the key is left ON, engine not running, the choke will not be energized, which is what you want.
One confusing wire issue: it is a red wire with white strip that runs through the harness all the way to a black plastic plug near the carburetor. On the other side of this connector, the red/white stripe wire changes to a solid blue wire which plugs on the choke.
Made a quick "RedneckRay" jumper wire, choke works for now, BUT it will stay energized anytime the key is left on:
I will install my "replacement" relay once it arrives.
I am curious IF a relay has to have a ground to operate? I am not an expert, but this is a simple 3 wire relay:
1) Red Wire - power with key ON
2) Red/white stripe Wire - to choke
3) Brown Wire - from alternator
So, when #3 shows 12 volts at the relay, it opens and allows #1 to flow down #2 to the choke. Is a ground necessary? I guess I will find out!!!
My notes:
